Cannot copy paste images from Jira Issue Description to Jira Issue Description
Philippe Grégoire
The copy-paste image functionality works fine when using, for example, the Windows Snipping Tool to do the Copy part of the operation, then Pasting the image within a Jira Server 7.7.1 issue description.
However, when I try selecting a Description which contains images, copying, then pasting in the Description of another Jira issue, everything looks right until I hit the Save button.
The images then get replaced by an Image Not found icon.
I have looked at the resolved issues in subsequent versions but have not seen anything.
For now, the workaround is using said Snipping Tool for the images.
Can anybody help out with this issue?
Regards
Tyler Brown
August 3, 2018
Hey Philippe,
When you have an issue on an issue does the file show up under the "Attachments" section of the ticket?
If so that would be the reason your issues aren't appearing as you have to attach the actual file to the new ticket as well.
Hope this helps,
Tyler
Philippe Grégoire
Hello Tyler,
no they do not show up. I know this is the issue, however Jira does automatically create the attachment when I do the scenario from Snipping Tool so it would be nice if it did the same on a Jira to Jira scenario.
Tyler Brown
August 3, 2018
If you're copying the Description from the issue could you just clone the issue?
That may bring over the attachment as well.
Philippe Grégoire
For now the workaround is:
  1. Copy text block
  2. Paste text block
  3. Snip image
  4. Paste image
  5. Repeat
And I'd like it to be:
  1. Copy text block and images
  2. Paste
The thing is that our workflow involves feature issues which have links and content that get kept up to date as improvements upon them get delivered so the clone workflow doesn't work either.
Randy
August 3, 2018
you can skip the snip part by just right clicking the image in the source issue and selecting "Copy Image" if your browser/OS supports it.  Then just paste to the new issue as you do if you grabbed from a snip.
Doesn't cut down your steps but eliminates launching a seperate app.
Philippe Grégoire
Thanks for the tip Randy, but using Chrome or IE I get the same result when I do a Copy Image.
Like Chris likes this
Chris
It's been a couple years since this was first posted, I'm experiencing the same issue. I have a script that generates a Jira ticket, then adds an image as a comment, and then I need to copy the image and paste it into an email. However, as of now, I still need to open the image and use the snipping tool or download the image and attach it.
I'm not able to just right click > copy image, like I can on any other website/image, then paste into word/outlook.
I saw an article about the trusted settings in Word, however when I checked I was already setup the way Atlassian recomends.
So I'm wondering if anyone was able to come up with a fix for this or not.
Like # people like this
Philippe Grégoire
Hello - please upvote if you think this is relevant.
Thank you!
greg_loeffelholz
I have no fix.  I have been cutting and pasting images into JIRA descriptions and comments for years.  Today for no apparent reason it simply stopped working.  I have cleared settings, logged out and back in, and confirmed I can paste into other applications.  This is super annoying and a major JIRA bug for a software that is supposed to save time.  Adding everything as attachments sucks.
bcostello
May 21, 2021
Still seeing this issue, As above I can paste once the image has been copied in a snipping tool . Cannot drag, or standard copy any images into replies. And as canned responses are not included in Jira, I cannot save useful repeated actions either, so these steps have to be repeated
Jason Cantrell
February 16, 2024
This should work, but doesn't:
In outlook or email editor:
  • Copy email with bullets, text and graphics.
In JIRA "reply to customer"
  • Paste (which includes all bullets, text and graphics)
What I must do:
  • Paste (which includes all bullets and text) but NO GRAPHICS
  • Find 1st graphic
  • Hunt and peck to find exact spot where 1st graphic goes
  • Paste 1st single graphic
  • Find 2nd graphic
  • Hunt and peck to find exact spot where 2nd graphic goes
  • Paste 2nd single graphic
  • Find 3rd graphic
  • Hunt and peck to find exact spot where 3rd graphic goes
  • Paste 3rd single graphic
Keep going until all graphics are found and pasted in the spot they reside.
Atlassian development: if you got annoyed and found it tedious at reading through this simple example IMAGINE how frustrating this is for a user of this product for every email, word document paste or copy that has graphics?
Please fix this.
Matthew December 10, 2023
I'm also seeing this issue. When I copy & paste from an Outlook email, the text pastes fine with its formatting, however the images are all missing. I then have to add each image separately by clicking the individual image within the email, copying, and pasting in the desired location in the Jira card. And when I paste the individual image as described, the "Preview unavailable" image placeholder suddenly appears above the image I just pasted:image.png
Amanda Coughlin April 9, 2024
If you create an automation rule you can select the field to copy description and attachment and that worked for me as a quick workaround. StoryAutomation.png
