Cannot create an issue of a specific issue type in epic
Florian Schlüter
For a Jira project I created a custom issue type called "Fristenüberwachung".
When I use the Create button from the main menu at the top, I can create tickets with the type Fristenüberwachung without any problems.
When I try to create a Fristenüberwachung issue within an epic, there is an error message saying that the issue could not be created (see screenshot).
If I choose any other issue type, there is no problem for creating issues from inside an epic.
If I create a Fristenüberwachung issue from outside of an epic, it works fine, and I can associate that issue with an epic afterwards.
Any idea on how to resolve that problem ?
3 votes
Martin Bayer _MoroSystems_ s_r_o__
Hi @Florian Schlüter , can you check the workflow for your issue type and it's initial transition? (Transition to your initial status). Do you have some conditions or validators set for it?
Florian Schlüter
I didn't set any conditions or validators.
Hm, that's weird. Can you translate the error message for me, please? :)
Florian Schlüter
It translates into:
We couldn't create subordinate issue.
Please check your connection and try again.
And then it proposes to either retry or abort.
I found one similar issue, but I'm not sure it can be coused in your use case (only one issuetype does not work) - https://jira.atlassian.com/browse/JRACLOUD-73555
But there is another hint. Can you go to developers console in your browser -> Network and check the error response for your create issue request?
Florian Schlüter
This is the response to the ajax request when I try to create an issue
ok, so can you check the create screen for your issue type?
Florian Schlüter
@Martin Bayer _MoroSystems_ s_r_o__
I got it, I didn't have the "summary" field on the screenmask for the "Fristenüberwachung" issue type.
I now added the "summary" field to it and now it works.
Thanks for your help.
