×Hi All,
After upgrading to the latest version 8.0 on a testing environment I cannot create any projects anymore. I checked with the known bugs and workarounds but they are not working.
Does anybody has glues for me too look?
===== Information =====
Jira version: 8.0
Postgresql: PostgreSQL 9.6.11
The following error has occurred:
lates-plugin:apply-project-template-handler threw an exception while handling a notification about a project being created
com.querydsl.core.QueryException: Caught PSQLException for insert into "AO_B9A0F0_APPLIED_TEMPLATE" ("PROJECT_ID", "PROJECT_TEMPLATE_MODULE_KEY", "PROJECT_TEMPLATE_WEB_ITEM_KEY") values (?, ?, ?)
at com.querydsl.sql.DefaultSQLExceptionTranslator.translate(DefaultSQLExceptionTranslator.java:50)
at com.querydsl.sql.Configuration.translate(Configuration.java:451)
at com.querydsl.sql.dml.SQLInsertClause.executeWithKeys(SQLInsertClause.java:364)
at com.querydsl.sql.dml.SQLInsertClause.executeWithKey(SQLInsertClause.java:172)
at com.querydsl.sql.dml.SQLInsertClause.executeWithKey(SQLInsertClause.java:153)
at com.atlassian.jira.projecttemplates.service.AppliedTemplateStorageImpl.lambda$add$0(AppliedTemplateStorageImpl.java:26)
at com.atlassian.pocketknife.internal.querydsl.DatabaseAccessorImpl.lambda$execute$18(DatabaseAccessorImpl.java:55)
at com.atlassian.sal.core.rdbms.DefaultTransactionalExecutor.executeInternal(DefaultTransactionalExecutor.java:87)
at com.atlassian.sal.core.rdbms.DefaultTransactionalExecutor.lambda$execute$0(DefaultTransactionalExecutor.java:43)
at com.atlassian.jira.database.DatabaseAccessorImpl.runInManagedTransaction(DatabaseAccessorImpl.java:131)
... 3 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
at com.sun.proxy.$Proxy48.runInManagedTransaction(Unknown Source)
... 3 filtered
at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:131)
at com.atlassian.sal.jira.rdbms.JiraHostConnectionAccessor.runInStartedOrExistingTransaction(JiraHostConnectionAccessor.java:130)
at com.atlassian.sal.jira.rdbms.JiraHostConnectionAccessor.execute(JiraHostConnectionAccessor.java:60)
at com.atlassian.sal.core.rdbms.DefaultTransactionalExecutor.execute(DefaultTransactionalExecutor.java:40)
at com.atlassian.pocketknife.internal.querydsl.DatabaseAccessorImpl.execute(DatabaseAccessorImpl.java:53)
at com.atlassian.pocketknife.internal.querydsl.DatabaseAccessorImpl.runInTransaction(DatabaseAccessorImpl.java:37)
at com.atlassian.jira.projecttemplates.service.AppliedTemplateStorageImpl.add(AppliedTemplateStorageImpl.java:20)
at com.atlassian.jira.projecttemplates.service.AppliedTemplateStorageCache.add(AppliedTemplateStorageCache.java:20)
at com.atlassian.jira.projecttemplates.service.ApplyProjectTemplateHandler.applyProjectTemplate(ApplyProjectTemplateHandler.java:61)
at com.atlassian.jira.projecttemplates.service.ApplyProjectTemplateHandler.onProjectCreated(ApplyProjectTemplateHandler.java:53)
at com.atlassian.jira.project.ProjectCreateRegistrarImpl.notifyAllHandlers(ProjectCreateRegistrarImpl.java:35)
at com.atlassian.jira.bc.project.DefaultProjectService.notifyHandlersOfProjectCreated(DefaultProjectService.java:392)
at com.atlassian.jira.bc.project.DefaultProjectService.createProjectInternal(DefaultProjectService.java:377)
at com.atlassian.jira.bc.project.DefaultProjectService.createProject(DefaultProjectService.java:347)
... 3 filtered
at com.sun.proxy.$Proxy462.createProject(Unknown Source)
... 3 filtered
at com.atlassian.jira.projecttemplates.service.ProjectTemplateServiceImpl.applyProjectTemplate(ProjectTemplateServiceImpl.java:173)
at com.atlassian.jira.projecttemplates.rest.ProjectTemplatesResource.createProjectFromFormRequest(ProjectTemplatesResource.java:170)
... 3 filtered
at com.sun.jersey.spi.container.JavaMethodInvokerFactory$1.invoke(JavaMethodInvokerFactory.java:60)
... 12 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter$JerseyOsgiServletContainer.doFilter(RestDelegatingServletFilter.java:159)
... 1 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter.doFilter(RestDelegatingServletFilter.java:69)
... 41 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 53 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
... 16 filtered
at com.atlassian.plugins.rest.module.servlet.RestSeraphFilter.doFilter(RestSeraphFilter.java:37)
... 19 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 10 filtered
... 4 filtered
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
... 26 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 24 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
Caused by: org.postgresql.util.PSQLException: ERROR: null value in column "ID" violates not-null constraint
Detail: Failing row contains (null, 10700, com.pyxis.greenhopper.jira:gh-scrum-template, com.pyxis.greenhopper.jira:gh-scrum-template).
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2455)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2155)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:288)
at org.postgresql.jdbc.PgStatement.executeInternal(PgStatement.java:430)
at org.postgresql.jdbc.PgPreparedStatement.executeWithFlags(PgPreparedStatement.java:168)
at org.postgresql.jdbc.PgPreparedStatement.executeUpdate(PgPreparedStatement.java:135)
at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:98)
at com.querydsl.sql.dml.SQLInsertClause.executeWithKeys(SQLInsertClause.java:335)
... 272 more
2019-02-12 20:39:21,492 http-nio-8080-exec-10 ERROR /rest/project-templates/1.0/templates [c.a.p.r.c.error.jersey.ThrowableExceptionMapper] Uncaught exception thrown by REST service: An error occurred while notifying that a project was created
java.lang.RuntimeException: An error occurred while notifying that a project was created
at com.atlassian.jira.bc.project.DefaultProjectService.notifyHandlersOfProjectCreated(DefaultProjectService.java:395)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
... 1 filtered
... 3 filtered
... 3 filtered
... 12 filtered
... 1 filtered
... 41 filtered
... 53 filtered
... 1 filtered
... 16 filtered
... 19 filtered
... 10 filtered
... 4 filtered
... 26 filtered
... 24 filtered
Table contents
-- Table: public."AO_B9A0F0_APPLIED_TEMPLATE"
-- DROP TABLE public."AO_B9A0F0_APPLIED_TEMPLATE";
CREATE TABLE public."AO_B9A0F0_APPLIED_TEMPLATE"
"ID" integer NOT NULL,
"PROJECT_ID" bigint DEFAULT 0,
"PROJECT_TEMPLATE_MODULE_KEY" character varying(255) COLLATE pg_catalog."default",
"PROJECT_TEMPLATE_WEB_ITEM_KEY" character varying(255) COLLATE pg_catalog."default",
CONSTRAINT "AO_B9A0F0_APPLIED_TEMPLATE_pkey" PRIMARY KEY ("ID")
WITH (
OIDS = FALSE
TABLESPACE pg_default;
ALTER TABLE public."AO_B9A0F0_APPLIED_TEMPLATE"
OWNER to user;
I "fixed" the problem by applying the following patch.
-- Column: public."AO_B9A0F0_APPLIED_TEMPLATE"."ID"
ALTER TABLE public."AO_B9A0F0_APPLIED_TEMPLATE" DROP COLUMN "ID";
ADD COLUMN "ID" serial NOT NULL PRIMARY KEY;
That I did was changing the interger to an serial so that the number is incementing. now the null error is gone!
Still a lot of errors are throws in the logs like:
/s/d5ff7374a c301c0d0ed5063fa4b41949-CDN/-hpjckb/800007/6411e0087192541a09d88223fb51a6a0/1.0/_/download/batch/jira.webresources:de lete-project-progress/jira.webresources:delete-project-progress.js [webresource] error in `Content.writeTo` for jira. webresources:delete-project-progress/DeleteProject.js
java.lang.RuntimeException: Cannot read resource /includes/jira/project/browse/view/DeleteProject.js
at com.atlassian.plugin.webresource.impl.snapshot.Resource$1.writeTo(Resource.java:200)
at com.atlassian.plugin.webresource.transformer.CompileTimeTransformer$1.writeTo(CompileTimeTransformer.java: 59)
at com.atlassian.plugin.webresource.impl.helpers.ResourceServingHelpers$8.writeTo(ResourceServingHelpers.java :466)
at com.atlassian.plugin.webresource.impl.helpers.ResourceServingHelpers$4.streamResource(ResourceServingHelpe rs.java:332)
at com.atlassian.plugin.webresource.transformer.TransformerUtils.transformAndStreamResource(TransformerUtils. java:38)
at com.atlassian.plugin.webresource.transformer.CharSequenceDownloadableResource.streamResource(CharSequenceD ownloadableResource.java:42)
at com.atlassian.plugin.webresource.impl.helpers.ResourceServingHelpers$5.writeTo(ResourceServingHelpers.java :351)
at com.atlassian.plugin.webresource.impl.helpers.ResourceServingHelpers$9.writeTo(ResourceServingHelpers.java :478)
at com.atlassian.plugin.webresource.impl.helpers.ResourceServingHelpers$2.lambda$writeTo$0(ResourceServingHel pers.java:188)
at com.atlassian.plugin.cache.filecache.impl.PassThroughCache.cache(PassThroughCache.java:18)
at com.atlassian.plugin.webresource.impl.helpers.ResourceServingHelpers$2.writeTo(ResourceServingHelpers.java :188)
at com.atlassian.plugin.webresource.impl.helpers.ResourceServingHelpers$7.writeTo(ResourceServingHelpers.java :379)
at com.atlassian.plugin.webresource.impl.helpers.ResourceServingHelpers$1.writeTo(ResourceServingHelpers.java :126)
at com.atlassian.plugin.webresource.impl.http.Controller.lambda$sendCachedInProduction$0(Controller.java:319)
at com.atlassian.plugin.webresource.impl.http.Controller.sendCachedInProduction(Controller.java:319)
at com.atlassian.plugin.webresource.impl.http.Controller.sendCached(Controller.java:282)
at com.atlassian.plugin.webresource.impl.http.Controller.serveResources(Controller.java:222)
at com.atlassian.plugin.webresource.impl.http.Controller.serveBatch(Controller.java:84)
at com.atlassian.plugin.webresource.impl.http.Router$7.apply(Router.java:112)
at com.atlassian.plugin.webresource.impl.http.Router$7.apply(Router.java:103)
at com.atlassian.plugin.webresource.impl.support.http.BaseRouter.callHandler(BaseRouter.java:171)
at com.atlassian.plugin.webresource.impl.support.http.BaseRouter.dispatch(BaseRouter.java:144)
at com.atlassian.plugin.webresource.servlet.PluginResourceDownload.serveFile(PluginResourceDownload.java:65)
at com.atlassian.plugin.servlet.AbstractFileServerServlet.doGet(AbstractFileServerServlet.java:28)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:635)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
... 44 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.ja va:21)
... 39 filtered
... 1 filtered
... 20 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:3 0)
... 12 filtered
... 7 filtered
at com.atlassian.jira.plugin.webresource.CachingResourceDownloadRewriteRule$1.execute(CachingResourceDownload RewriteRule.java:60)
at org.tuckey.web.filters.urlrewrite.RewrittenUrlClass.doRewrite(RewrittenUrlClass.java:61)
... 6 filtered
... 10 filtered
... 4 filtered
... 26 filtered
... 24 filtered
and also this database (again...) related error:
org.postgresql.util.PSQLException: ERROR: relation "public.AO_4789DD_HEALTH_CHECK_STATUS_ID_seq" does not exist
Position: 16
at com.atlassian.activeobjects.internal.EntityManagedActiveObjects.create(EntityManagedActiveObjects.java:94)
at com.atlassian.activeobjects.osgi.TenantAwareActiveObjects.create(TenantAwareActiveObjects.java:279)
... 3 filtered
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:343)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker. java:56)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.ja va:60)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:185)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionIntercep tor.java:136)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor .java:124)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTC CLInterceptor.java:70)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLIntercepto r.java:53)
at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAd vice.java:57)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:212)
at com.sun.proxy.$Proxy2186.create(Unknown Source)
at com.atlassian.troubleshooting.healthcheck.persistence.service.HealthStatusPersistenceServiceImpl.storeNewF ailure(HealthStatusPersistenceServiceImpl.java:90)
at com.atlassian.troubleshooting.healthcheck.persistence.service.HealthStatusPersistenceServiceImpl.storeFail edStatuses(HealthStatusPersistenceServiceImpl.java:71)
... 3 filtered
Caused by: org.postgresql.util.PSQLException: ERROR: relation "public.AO_4789DD_HEALTH_CHECK_STATUS_ID_seq" does not exist
Position: 16
at org.postgresql.jdbc.PgPreparedStatement.executeQuery(PgPreparedStatement.java:116)
at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:83)
at net.java.ao.db.PostgreSQLDatabaseProvider.insertReturningKey(PostgreSQLDatabaseProvider.java:284)
at net.java.ao.EntityManager.create(EntityManager.java:366)
at com.atlassian.activeobjects.internal.EntityManagedActiveObjects.create(EntityManagedActiveObjects.java:92)
... 178 more
^C
If you are making manual database modifications, you are going the wrong direction. This is almost never a part of the upgrade process.
I would revert to the original version of Jira that you started out with. Make sure that the database user has the correct grants and try the upgrade again. I haven't seen any documentation to indicate what the earliest version of Jira that directly allows upgrade to 8.0, but I would assume that if you are on 7.3 or later, you can probably go directly. If you are on a version earlier than 7.3, I would upgrade to that version, update all the Apps, upgrade to 8.0 and upgrade the Apps again. If that doesn't work, I think your best solution will be to open an Atlassian Support request.
I cannot ask for a Atlassian Support request because I have a start license :(
I am aware that it is not the best solution but it works. The related sql error Caused by: org.postgresql.util.PSQLException: ERROR: relation public.AO_4789DD_HEALTH_CHECK_STATUS_ID_seq" does not exist
This was caused by a out of date plugin, also mentioned in the kb of atlassian.
I also tried to uninstall and re-install a fresh install on a enpty database and then I was unable to login. I will check the reverse proxy for clues, it might be causing issues even the configuration looks ok.
Postgres 9.6 is supported. I'd open an Atlassian Support request. Something really bad happened. You are running Java 8 or OpenJDK 8, right?
Yes, openJDK8 is installed but as far as I can see the bundled version is used.
Also in the logging and processes I see that JIRA is started with the bundeled one.
I cannot get any support because we use the starter license :(
Sounds like you have a sane setup. Hopefully this was a test instance. You might try removing your catalina.out and atlassian-jira.log files, then restarting. You'll only have logs from that startup, which can make it easier to see what's going on.
Yes, it is a test instance that I updated.
The data is to big to post here so I shared two files trough google docs.
catalina.out: https://drive.google.com/open?id=1S97tXtaKLs2d6Dwru_R6_wlQNDlA34vH
and
atlassinan-jira.log: https://drive.google.com/open?id=1Dh6WF6U2JENWN51kpRhaxeP_ZLSUFT9N
EDIT: I see that the driver version is older then the database version, could that be a problem?
