I tried to enable the roadmap feature following this documentation:
https://confluence.atlassian.com/jirasoftwarecloud/roadmap-955164013.html
But in our Jira Software Cloud I cannot find item "Features" in project settings. Can anybody help me on that....
Thanks in advance,
Miriam
Hi @Miriam Weber,
The link appears to differ from this link on the documentation.
Could I also ask, which project type did you use for the Next-Gen Project? I used a Scrum type project and I was able to access the features page with the Roadmaps option.
Hope this helps
Yes I had a different link. In your link it is mentioned that it is only available in next-gen projects. I think we have classic projects - so that might be the reason I didn't find it.
Will the roadmap feature also be available for classic projects in the future or will it be possible to convert classic projects to next-gen projects? Otherwise we will not be able to use that feature :-(
Thanks for your comment anyway - you helped me a lot!
Hi @Miriam Weber,
Yes, only next-gen projects. I would love to have access to the Roadmap feature in some of my classic projects too, however it seems to be only available in Next-Gen Projects for now.
You may want to look into using Portfolio for Jira.
Hope this helps
