Cant' find project from Power Automate Microsoft
phongtd January 31, 2025
I am using Power Automate Microsoft, I want to auto create the Task in Jira. First, I add the connection to Jira and it work. Next I add the Action Create Task Jira, It can't show the full list of project, I can't find the project I am working on. Please help me to check it.
Valerie Knapp
Hi @phongtd , thanks for your post.
Have you seen this - https://community.atlassian.com/t5/Jira-Service-Management/Create-JIRA-issues-using-MS-power-automate-HTTP-post/qaq-p/2686788
Maybe it will help you resolve your problem?
If not, please write again and we will try to assist.
Cheers
phongtd February 1, 2025
Thanks for your reply,
It another way to resolve my problem. Maybe I will go on your way.
I am using this Action:
sambhaji.gaikwad
February 22, 2025
Exact same issue. Does list several other projects but not the one I am looking for.
It would have been nice to see what caused drop.
First I tried Get issue by key but then later just to check I tried Get projects.
Event get project is also not giving the project I am looking in the response body.
Like phongtd likes this
