I have a request from the user base to be able to capture github pull request comments after merge to the comments field in Jira. I've grepped Google extensively and find bits of it but nothing that really solves the problem.
Has anyone else had this need and found a solution? Even if it were an issue property that one could suck in to some other place, that would work as well.
Looks like this exists: https://marketplace.atlassian.com/apps/1219592/github-for-jira?tab=support&hosting=cloud - but it only works for cloud version of Jira, right now.
Thanks @mikutech ! I am in the process of migrating to cloud and DO have this connection in there but had not yet explored it.
That's an integration but I don't see anything about functionality for loading GitHub PR comments into JIRA, which I believe was the original request?
