Hello! When you go to Card Layout and add Linked Issues.. it shows the Issue's ID that is linked. I want to know is it possible to show the Summary of the Issue on the card as opposed to the ID?
I think it's more efficient for developers to see the name of the issue (summary) rather than the Issue ID?
Please advise.
You say you see the Summary of the linked issue on an issue card's layout. But in your example I just see BOR-4m BOR-5 on BOR-1. Test 1 is the summary of BOR-1. So you still don't see the summaries of the linked issues. So it seems you don't understand the objective here, am I right @cierralewis.
Could @somethingblue or someone please still give an answer?
Hi Cierra,
When I create a Linked issue I am able to see the Issue Summary in Cloud and Server without any changes:
Please take a Screenshot of what you're seeing and we'll go from there.
Branden
I am using Server.. currently when I view my issues, as you can see the linked issue only shows the Issue ID (MFA-24) and not the summary of the ticket
Hi Cierra,
What is the issue type of the linked issue (MFA-24)? I noticed that if the linked issue is an Epic it doesn't show the Summary:
Please confirm the linked issue type and we'll go from there.
Branden
Hello I would also like to know more about this because I have the same problem/inquiry regarding showing the Issue Summary on the linked issue. I want the linked issue summary to be shown in the card layout.
