Cast issue attachment in base64 string
Antoine [Klee Group]
March 15, 2023
Hi.
I wish to send Jira issue's attachments to another software using json.
The final goal is to produce a json of that kind.
"attachments": [{
"b64content": "whatever b64 string ==",
"name": "image.png"
I am using scriptrunner do perform this action. It seems like the AttachmentManager.streamAttachmentContent can do the job but I do not know how to use the InputStreamConsumer (Atlassian Jira - Server 9.3.3 API) class.
Here is the code I use so far.
import groovy.json.*
import org.apache.log4j.Level
import org.apache.commons.codec.binary.Base64;
import com.atlassian.jira.issue.AttachmentManager
import com.atlassian.jira.issue.attachment.Attachment
log.setLevel(Level.INFO);
def attachmentManager = ComponentAccessor.getAttachmentManager()
def issue = issueManager.getIssueObject('PTIJ-68')
def attachment_list = issue.getAttachments()
// Once I have the list, I am working on the first attachment right now and try to stream it as a list of bytes but do not know how to open the stream.
log.info(attachmentManager.streamAttachmentContent(attachment_list[0], ??? ))
Can anyone help?
3 votes
Ram Kumar Aravindakshan _Adaptavist_
Hi @Antoine [Klee Group]
If you intend to encode the attachments to Base64, why not try something like this:-
import com.adaptavist.hapi.jira.issues.Issues
def issue = Issues.getByKey('MOCK-3')
def encoding = [] as List<String>
issue.attachments.each {
encoding << it.toString().bytes.encodeBase64().toString()
encoding
Please note that the sample code above is not 100% exact to your environment. Hence, you will need to make the required modifications.
Below is a screenshot of the output returned:-
You will basically have to pass the List of encoding values returned into your JSON.
If you intend only to take the first Attachment, you could modify the code slightly to:-
def attachment = issue.attachments.sort {it.created}.first()
attachment.toString().bytes.encodeBase64().toString()
 Below is the screenshot from the ScriptRunner console:-
Also, I have run the test above using ScriptRunner's HAPI feature. I suggest upgrading your ScriptRunner plugin to the latest release, i.e. 7.13.0, to use the HAPI feature.
I hope this helps to solve your question. :-)
Thank you and Kind regards,
Ram
November 9, 2023
Hi Ram sorry i completely missed your comment.
I will try your solution asap.
My environnement is: Scriptrunner v5.5.2 / Jira Server v7.13.2
November 13, 2023
Hi @Ram Kumar Aravindakshan _Adaptavist_
Thanks for your answer but that is not really what I want.
the `attachment` variable, then encoded to b64 in your script just encodes the string "com.atlassian.jira.issue.attachment.Attachment@ff95584b" into its b64 counterpart. I wish to have the whole binary stream of the attachment to be turned into a b64 string, not just the descriptor.
Thanks.
Parvaneh Zand
December 18, 2023
Did you find a solution?
December 20, 2023
Hi @Parvaneh Zand infact I found a solution, basically I perform a GET requests on the "contentURL" of the attachment. Did not find a way to do this internally.
Here is an extract of my code:
def issue_all_attachments = issue.attachments
log.debug(issue_all_attachments)
List issue_all_attachments_list = []
issue_all_attachments.each{
Map<String, String> issue_all_attachments_map = new HashMap<String, String>()
issue_all_attachments_map.put("filename", it.getFilename().toString())
issue_all_attachments_map.put("localContentURL", "http://localhost:8080/secure/attachment/" + it.getId().toString() + "/" + it.getFilename().toString())
issue_all_attachments_list.add(issue_all_attachments_map)
log.debug(issue_all_attachments_list)
log.info("Conversion to b64")
for (my_attachment in issue_all_attachments_list) {
try {
def request_url_attachment = new URL(my_attachment.localContentURL);
HttpURLConnection get_attachment_request = (HttpURLConnection) request_url_attachment.openConnection();
get_attachment_request.setRequestMethod("GET")
get_attachment_request.setDoOutput(true)
get_attachment_request.setRequestProperty("Authorization", JIRA_AUTH_STRING)
my_attachment.put("base64content", get_attachment_request.getInputStream().bytes.encodeBase64().toString())
catch (e) {
log.error("error message = ${e}")
my_attachment.put("base64content", "")
 This will create an array of the following format:
[{content:<b64string>,filename:<string>},{content:<b64string>,filename:<string>}]
