Change Jira System Encoding from Cp1252 to UTF-8
Callum Carlile _Automation Consultants_
I have added the following JVM parameter "-Dfile.encoding=utf-8" to the setenv.bat file and have restarted Jira, amd have followed all documents online how to update the system encoding but it is still Cp1252 and I can't work out why this isn't changing. Please may someone help!
7 votes
Mehmet Şirin Usanmaz
March 22, 2019
Hi Callum,
You can try set "-Dfile.encoding=utf-8 -Dsun.jnu.encoding=UTF-8"  JVM arguments .
https://confluence.atlassian.com/adminjiraserver073/setting-properties-and-options-on-startup-861253969.html
Mehmet Sirin
Hi @Mehmet Şirin Usanmaz
Thank you for your reply, this worked for me, thank you!
mete.c December 11, 2020
it's worked for me also. Thanks.
Hamza ZERGUINE
September 27, 2021
thanks mehmet.
can we apply this manipulation on a production environment where several projects are in use without risk?
