Change assignee from issue to linked issue.
Max October 13, 2023
I'm trying to set up an automatic Assignee change in related tasks.
If Reporter is changed in a task, in some related tasks, I need to change Assignee to Reporter in the main task.
Is there an example of a trigger in Script runner that performs this functionality?
Salzi
October 13, 2023
Hi @Max ,
do a custom script listener in Scriptrunner for the event issue updated and then filter whether the reporter has changed.
With HAPI you can easily set the assignee. Here's an example:
def issue = Issues.getByKey('IS1-6')
def orgIssueReporter = issue.getReporter()
log.warn(orgIssueReporter)
def linkedIssues = issue.getOutwardLinks()
linkedIssues.each { it ->
def linkedIssue = it.destinationObject
linkedIssue.update{
setAssignee(orgIssueReporter)
Max October 17, 2023
Thanks for the example.
I can't understand why I get an error in one case and an empty list of related tasks in the other case.
The script is like this:
def issue = event.getIssue()
def issueKey = issue.getKey()
//def issue = Issues.getByKey('JIRA166-163')
def issueSummary = issue.getSummary()
log.warn(issueSummary)
log.warn("Linked issue" + linkedIssues)
    log.warn("Linked issue 2" + linkedIssues)
    linkedIssue.update{
Salzi
October 17, 2023
Hi @Max ,
In one example, the user does not have permission to be an assignee in this project.
And on the other hand, you would have to add the InwardLinks to the linkedIssues (unfortunately there is no function in HAPI that gets all the links). You can simply add both lists together:
def linkedIssues = issue.getOutwardLinks() + issue.getInwardLinks()
Max November 1, 2023
Hi @Salzi, Thank you, for your help. It's working.
Craig Nodwell
Hi @Max this can be done, but can you be a little more clear on the ask.  Why would a reporter change?
This is how the process is structured. From one project, related tasks are automatically created in other projects. And Reporter is responsible for them. If a task is transferred to another employee, then all related tasks are also transferred to him.
