Change hierarchy level for idea discovery project in jira plans
Ka Silveira
Hello! I'm using a Discovery Project for manage ideas and group epics in delivery but I need to fix the hierarchy of it in Jira Plans. When ideas are displayed in the plan, they appear with the same level as standard issues (story for example). But I need them to have the same level of an initiative.
Walter Buggenhout
Hi @Ka Silveira,
Ideas are a feature from the very new Jira Product Discovery product, which is currently in beta. Discovery project are team managed only, which means that the idea issue type is not shared globally across Jira. And that is why you can't add it to the hierarchy.
There are currently some known limitations with the product, which you can read in this community article.
Hope this helps!
Ka Silveira
Thanks!
Felipe Sanchez
December 15, 2023
@Walter Buggenhout, do you know if this is currently available, given that JPD is no longer in Beta?
