Hi there,
We have changed Home directory location from '/Var' directory to '/opt' directory due to insufficient Storage. We have also updated location in '.properties' file but at last it resulted in some index problem. we can find the updated/current location i.e opt directory every where on UI except one place i.e at 'jira.path.attachments'.
PFA for updated Locations
Here is the location where it is not updated!!
Hi @mohammed aamer khan ,
From jira version 5.2 and beyond, policy was enforced and JIRA will refuse saving attachments if a custom path is defined. Create a symbolic link on your server from the default attachment path (<JIRA_HOME>/data/attachments
) to the path where you want your attachments to be stored.
Steps to do is mentioned in https://confluence.atlassian.com/jirakb/change-the-attachments-directory-location-for-jira-server-237569020.html
Hi @Rilwan Ahmed
Sorry for late reply but the way you have mentioned is with out moving home directory location. But as I told I have already changed Home directory location from /var to /opt. Now I want to update 'jira.path.location' as I have attached screenshot. Let me know if you knows any work around after changing location.
