I've recently changed a project key, and I understand it takes a while to re-index.
Everything is working absolutely fine, and I made the change 10 days ago. However I can still see traces of the old project key in the Roadmap, Backlog & Active Sprint breadcrumbs.
Also, when selecting a sprint for a story the options still show the old key for the board that the sprint is in.
Is this expected or will the re-index eventually catch all instances of the project key?
Many thanks.
Hi @Matthew , that is strange indeed as it shouldn't take that long.
Have you tried clearing your browser cache?
Yes I have quite a few times, its weird huh?
It appears to just be the Board name that hasn't updated. The Project Key should be CIP, and all the epics & stories have updated fine. But wherever it references the board it uses the old Key which was ATH.
Do I need to change the Board Key somewhere else?
Thanks for your reply.
Yes, board names is another thing. Glad you found the reason.
