I'd really like to use the JIRA roadmap feature and it is only available for a new "Next-gen" project, I cannot change an existing project.
What would be the implications of creating a new project and then moving all the JIRA issues to it ?
What else would need to be done ?
That is the only way to migrate a classic project to a next-gen project. Just make sure that next-gen projects is a good match for you because next-gen projects lack lots of features of classic projects currently.
There is not document like this. But here are some of the most important missing features:
- no subtasks
- no versions
- no components
- you can not change workflow
- no select custom fields
Of course, next-gen projects are under active development and maybe this features will be available later.
