Checklist template load automation
Sona Evanesyan
HI community,
I use Checklist add-on free version ,
I have created a checklist template and want to automatically load that checklist template while creating a new issue in that project ? How to do it ? Cannot find the right action that need to chose after issue creation.
Thanks in advance
Jack Hunter [HeroCoders]
HI @Sona Evanesyan
If you use Issue Checklist Free then you can make the template default for a project and issue type. After that, all newly created issues will get the checklist automatically. Here is the guide: https://herocoders.atlassian.net/wiki/spaces/IC/pages/776896599/Setting+a+template+as+default+checklist
Also, if you clone the issue that has the checklist in it, the checklist gets cloned as well.
 Let us know if you have more detailed questions.
Jack
Olena Brazhko_TitanApps_
August 25, 2021
Hi @Sona Evanesyan,
You can check out the Smart checklist for Jira. Free version.
It’s simple to use, and it takes only several steps to set a checklist template to appear by default on issue creation. To do it:
  1. Install Smart checklist for Jira add-on
  2. Create a checklist template
  3. Set a template as default
You can also set a specific template to appear by default depending on the issue type.
If you have any questions or need assistance, feel free to reach directly to our support team at smartchecklist@railsware.com.
Best regards,
Arun Makhija
How do I use the smart checklist from Template in JIRA automation as I need to use it in multiple rules ? TIA
Danno
I'm guessing you picked
Issue Checklist for Jira. Free
It appears they allow you to save a template to reuse but I would think you could just clone the issue with the appropriate checklist to reuse.
Sona Evanesyan
Yes , and found the solution .
https://herocoders.atlassian.net/wiki/spaces/IC/pages/922353675/Applying+a+template+automatically
Can chose as default template .
Jack Brickey
Can you please provide the precise add-on that you were using such as the link to the marketplace app?
Jack Brickey
Great! I actually use that app as well, the paid version.
If you go into manage templates you should be able to set one of the checklist as the default which would result in the checklist being created or added every time you create the issue. Let me know if this isn't obvious.
