Child issues not showing up
James Walters
Hi there, I'm having a weird issue. I've set up a new board, but when I add child issues to either Epics or Tasks, they initially show up, but if I click off the Epic or refresh the page, they disappear from the preview.
They still display in the Timeline (when it comes to tasks), but not in the preview:
If I open the Epic or the Task directly in a new window, the child tasks are also hidden, so it's not limited just to the Timeline preview:
If I add a new Task or Subtask, the list will display again:
However, if I refresh or click off then back onto the Task, the child issues vanish. They're still present and can be searched for, but don't display on the parent ticket:
It's only happening in new boards, though - I have two other boards, one on the same user, which is displaying normally:
And another separate user account I use for work:
These other boards both display fine, so I'm confused as to what the issue might be with this new board...
I've tried deleting and creating a new board, to see if it was a random issue, but this same issue occurs on any new software project board (team managed) I set up.
Pasam Venkateshwarrao
April 14, 2025
Hi @James Walters
welcome to the community,if child issues are not showing then there will be one of the following
Check Issue Type Hierarchy
  • Jira needs to recognize the parent-child relationship (like Epic → Story → Sub-task).
  • Go to:
    Jira Settings → Issues → Issue Type Hierarchy
In the Issue View:
  • Open a parent issue (Story/Task) → check the “Child issues” panel.
    • If it’s missing, they might not be linked properly or are using the wrong issue type.
Make Sure Child Issues Are Actually Linked
  • Sub-tasks: Must be created as Sub-tasks, not just linked issues.
  • Stories under Epics: Must have the “Epic Link” field filled out.
Permissions Issues
  • You may not have access to the child issues due to:
    • Project permissions
    • Issue security levels
        Ask your Jira admin if:
  • You have Browse Projects permission
  • The issue has a Security Level that hides it from you
Hope this helps
April 15, 2025
@James Walters the steps which i have shared is it helps to you
sanam malleswari
April 14, 2025
Hi @James Walters
Is this company managed project or team managed project?
Try to enable child level issues in the board configuration>> Timelines by using below link.
Unable to view child issues under an Epic when using Jira Software Roadmaps | Jira and Jira Service Management | Atlassian Support
FREE
