Clear a Field using ScriptRunner
SMAtlassianMber
I have added the following Behaviour, but I also need to make sure the Fixed Deadline Date field is cleared if the Fixed Deadline is No. Would I need to add something like this to last line in else
issue.setCustomFieldValue(fxieddeadlinedateField, null)
def fixeddeadlineField = getFieldByName("Fixed Deadline")
def fixeddeadlinedateField = getFieldByName("Fixed Deadline Date")
if (fixeddeadlineField.value.toString() == "Yes") {
fixeddeadlinedateField.setRequired(true)
fixeddeadlinedateField.setHidden(false)
else {
fixeddeadlinedateField.setRequired(false)
fixeddeadlinedateField.setHidden(true)
SMAtlassianMber
I got this to work.
def defaultValue = null
else {
fixeddeadlinedateField.setFormValue(defaultValue)
Steven F Behnke
November 29, 2018
The documentation states that there is a 'setFieldValue("")' method -- You should be able to pass in a Blank String or a null.
SMAtlassianMber
When i try the following, I get the variable "issue" is undeclared
else {
issue.setCustomFieldValue(fixeddeadlinedateField, null)
