Clone Issue Test Execution
Hasan Atasoy August 12, 2019
I want clone test Execution, summary the incontent test. But If i clone it, then i get not the Tests in cloned Issue.
Deleted user August 12, 2019
Hi @Hasan Atasoy ,
If you are using the native clone operation to clone the all other third party related fields, you will not be able to do.
You can try with any other clone apps that are in the marketplace to do so.
Sravya
Hasan Atasoy August 13, 2019
Hi Sravya,
my college  has tested with the same app, at his other account on a other company "effectiveqa.atlassian.com". He has success. I think the problem is not with the clone app.
