Clone an issue to projects
Antonio D'Errico
Hi everyone,
it is possible to clone an issue to one or more projects based on a projectlist?
here is an example:
an issue needs to be cloned to four jira projects. i want to execute a transition called for example "clone issue to projects". then a list comes up in which i need to define to which projects this issue needs to be cloned.
best
toni
Antonio D'Errico
Rest Endpoint
import com.onresolve.scriptrunner.runner.rest.common.CustomEndpointDelegate
import groovy.json.JsonBuilder
import groovy.transform.BaseScript
import groovy.json.JsonSlurper
import javax.ws.rs.core.MultivaluedMap
import javax.ws.rs.core.Response
@BaseScript CustomEndpointDelegate delegate
getProjects(httpMethod: "GET", groups: ["jira-software-users"]) { MultivaluedMap queryParams, String body ->
def query = queryParams.getFirst("query") as String
def prList = ComponentAccessor.getProjectManager().getProjectObjects()
def filtertList = prList.findAll { project -> project.getName().toLowerCase().contains(query.toLowerCase()) }
def rt = [
items : filtertList.collect { project ->
value: project.getName(),
html : project.getName(),
label: project.getName(),
displayName: project.getName(),
total : filtertList.size(),
footer: "Wähle das Projekt aus ...",
return Response.ok(new JsonBuilder(rt).toString()).build()
behaviour
def searchField = getFieldByName("Projekt")
searchField.convertToMultiSelect([
ajaxOptions: [
url : "BASEURL/rest/scriptrunner/latest/custom/getProjects",
query: true, // keep going back to the sever for each keystroke
minQueryLength: 1,
keyInputPeriod: 500,
formatResponse: "general",
Tarun Sapra
Hello @Antonio D_Errico
Great to see the complete code sample, if you think my answer helped you in your requirement please upvote/accept. thanks!
Tarun Sapra
Yes this is possible. When you click on a transition then you can have a transition screen and in that transition screen you can have a variable which is a "project picker" custom field.
Base don the values selected in the project picker custom field you can select the projects in which to clone the issues in the post-function of the transition. And once the cloning is done then you can clear the custom field for next time.
Tarun Sapra
Also, since Jira doesn't support multi-select project picker. Thus, you can create a custom field like the ones here which displays dynamically the actual list of projects
https://scriptrunner.adaptavist.com/latest/jira/behaviours-conversions.html
Antonio D'Errico
i dont find the example for a mutliselect field for projects only for issues
Tarun Sapra
The example of issues is there, you can create a similar example for projects using REST API call which you also described. Basically use REST API to fetch project list and then let user mult-select options from the list.
Antonio D'Errico
hi @Tarun Sapra
i am not  familiar with the rest api and the groovy. so i am a little bit lost at this moment.
i understand that i need a rest endpoint but i am not able to build it up.
how should the rest endpoint look like:
doSomething(
httpMethod: "GET", groups: ["jira-administrators"]
return Response.ok(new JsonBuilder([abc: 42]).toString()).build()
best regards
toni
Tarun Sapra
I am not talking about created a custom REST endpoint but calling the REST API of JIRA
https://scriptrunner.adaptavist.com/latest/jira/behaviours-conversions.html#_walkthrough_external_rest_service
In the above  example they are calling REST API of confluence but you can call REST API of JIRA which returns the project list.
https://docs.atlassian.com/software/jira/docs/api/REST/7.6.1/#api/2/project-getAllProjects
Antonio D'Errico
hi @Tarun Sapra
ok thank you.
the initilaiser looks like this but the field says no matches.
getFieldByName("Projekt").convertToMultiSelect([
ajaxOptions: [
url : getBaseUrl() + "/rest/api/2/project",
query: true,
If i open the api call over my brower i get the json output.
Tarun Sapra
In the call you have to parse JSON and then it will work.
LIke in one of the examples in the link i shared they are parsing the response so you have to parse the response as well.
def response = httpBuilder.request(Method.GET, ContentType.JSON) {
uri.path = "/rest/api/2/issue/picker"
uri.query = [currentJQL: jqlQuery, query: query, showSubTasks: true, showSubTaskParent: true]
response.failure = { resp, reader ->
log.warn("Failed to query JIRA API: " + reader.errorMessages)
return
response.sections.each { section ->
section.issues.each {
// delete the image tag, because the issue picker is hard-coded
// to prepend the current instance base URL.
it.remove("img")
return Response.ok(new JsonBuilder(response).toString()).build()
