Clone an issue without a Custom field
Prabhu Prabhakar
Hi
 While cloning an issue I just want to clear a Custom field, the field type is checkbox,just want to uncheck on the Cloned issues.
Is there any way I can resolve it?
Praba
Sachin Dhamale
@Prabhu Prabhakar
While Cloning there is no way to make change but After cloning the issue you can edit that issue and make the required change
Sachin
Prabhu Prabhakar
Hi @Sachin Dhamale
There is no possiblities with the script runners/other plugins as well is it?
Prabakaran.
Sachin Dhamale
Through Script runner you can do that
there is post function in script runner through that you can select the field which you want to copy
OR Third Party Plugin you can try this
Deep Clone for Jira
Clone plus for jira.
Accept the answer if it helps
Marlene Kegel - codefortynine
Hi @Prabhu Prabhakar,
I am Marlene from codefortynine.
Your use case is possible with Deep Clone for Jira.
You can clear any checkbox field with the Deep Clone Field Editor, which means that in all clones the checkbox will be cleared.
Prabhu Prabhakar
Hi @Marlene Kegel - codefortynine
Thanks! But this is not available for Data Center.
Sorry, that's correct, @Prabhu Prabhakar. Deep Clone for Jira is only available for Jira cloud.
