Cloning cards & their child issues
Brittany Melville
I know how to clone a card, but how can I clone a card along with all of its child issues? Or is there an easier way to create a template that can be repopulated and reused over time?
Aaron Brady
Hi Brittany,
Welcome to Atlassian!
To clone the subtasks associated with a story or task you simply need to check the box next to subtasks and then click clone:
If you want to clone epics, or entire projects, you should use a tool like Deep Clone. There are several redundant tasks that I have created templates for. When I need to clone them, I simply clone the epic and all of the stories that belong to it.
https://marketplace.atlassian.com/apps/1218652/deep-clone-for-jira?tab=overview&hosting=cloud
Hope this helps!
-Aaron
Brittany Melville
Hi Aaron,
That makes perfect sense now. For some reason last week when selecting the 'clone' option, I wasn't getting that second window with the checkboxes to include subtasks. I see it now.
Also appreciate you sharing the other resource for cloning projects.
Thanks for your help!
Brittany
Like Aaron Brady likes this
FREE
