Can you explain more what you mean?
You mean to write a code block inside fields like description?
Like this:
public Response jsonData() throws Exception {
return ...
Hi Nir,
You mean to write a code block inside fields like description? - Yes, i thought in description field.
But, User had written a code in "Comment" section. It will allow in comment section ? And user has complained that it doesn't seem to work in my JIRA. Please note right now this field is using a plain text not a WIKI TEXT RENDERER.
please suggest me on this.
Hi @Roja Gurram
In the ticket comments you can also add code block, it's built in with Jira.
And every multi text customfield can be converted from plain text to wiki text render and than also have code block.
Hi Nir,
Fantastic, Thank you very much for the quick response.
I will check and let you know the update.
Hi Nir,
The solution you have shared is worked good. Thanks.
