Comment formatting is not working as expected
Foram May 3, 2023
1. unable to give bullets for ordered and unordered list
2. Bold, Italic, and underline are not working
3. Unable to add the table in the comment section
Alex Koxaras _Relational_
Hi @Foram and welcome to the community,
Check that the comment field, under field configuration, has the wiki renderer and not the text renderer.
Foram May 5, 2023
Got it.
Thank you so much.
@Foram did you solve your problem?
Foram May 7, 2023
Yes
Thank you so much.
@Foram kindly mark my answer as accepted then, in order to help others in the community with similar problems. Much appreciated!
Like Foram likes this
xenangonline
May 4, 2023
Kiểm tra xem trường nhận xét,  Vui lòng
FREE
