Como hacer que un campo de tipo Group Picker sea modificable su contenido
Víctor Hugo Ortega Tenorio June 23, 2022
How to change a field so that the information is editable
Julien Dephix
What field do you want to be able to edit?
Víctor Hugo Ortega Tenorio June 27, 2022
The field is type Group Picker
Julien Dephix
Someone had a similar question on the forums and were pointed to https://support.atlassian.com/cloud-automation/docs/advanced-field-editing-using-json/
Might help you.
Víctor Hugo Ortega Tenorio June 29, 2022
Excellent. Thanks !!
