Components - adding to existing issues
Harry Zolkower
July 28, 2020
I created Components in Jira and then tried to assign them to already created Epics, but the Component field is not displayed or hidden.  How do I update existing records with the newly created Components?
Note:  This is the first time project has Components (after the fact the issues were already created).
Thanks in advance for your assistance!
Sachin
July 28, 2020
hello @Harry Zolkower ,
You need to check your
- Field configuration to see if the components field is not hidden
 - as project admin goto project settings --> fields --> Components (if the field is hidden you need your jira admin's help to Show it on your project)
- You also need to make sure Components field is added to your create/edit screen
 - as project admin goto project settings --> Screens --> Edit Screen
If components field is not hidden and is on the required screens, you can goto your issue and add components
Harry Zolkower
July 28, 2020
Thank you Sachin!
Sachin
July 28, 2020
your welcome Harry.
