Components not taken into Issue
Cristina Andrei
When I create a new issue, and adding components to the issue (in the edit mask), they do not get taken over into the issue itself. What is the problem and can be solved?
Nic Brough -Adaptavist-
April 12, 2023
How are you adding components during the issue creation?  Is it a field on the create screen?  Are you talking about the "system" field for components?  (the one the project admins can maintain the options for)
Cristina Andrei
yes it is a field on the create screen. practically after i press the create button, it is open that pop to complete the summary, assignee, component etc.
on the component field i choose a component (laptop for example) then i press on the create button -> the issue is created but the component field is empty even i have choosed some component to filled.
April 12, 2023
Ok, so that suggests that you have a post-function, listener, or Automation that is clearing the component field as you create it.
Does the issue history have anything in it after you create an issue with this problem?  That might capture an Automation or listener dropping your input.
Cristina Andrei
After the issue is created on issue history i can see  that the component has been removed.Even no one has removed that component
I checked also the postfunction but there is nothing to clear the component after is created.
April 16, 2023
The issue history does not contain the initial issue creation.
So if your issues are being created with Component filled in on-screen, and ending up with no components after creation, with no line in the history saying "someone deleted it", then you have a post-function removing it before issue creation.
Fabio Racobaldo _Catworkx_
Hi @Cristina Andrei ,
please verify that compont/s field is in your view screen and it is not hidden in the related field contiguration.
Hope this helps,
Fabio
Cristina Andrei
It is not hidden
Cristina Andrei
