Hi all,
I'm currently using a Confiform in Confluence to create Issues within a Jira project using the app-link connection and an IFTTT macro with a nested No format macro containing JSON as described in https://wiki.vertuna.com/display/FORMS/How+to+create+a+form+to+create+a+Jira+issue+from+Confluence
By using this method, or something similar, how would you create a Jira issue, with additional nested issues e.g. a parent Epic with a number of child Tasks or a Parent Task with a number of child sub-tasks.
Curious if this is achievable and appreciate any advice to how to get it done.
Drew
Hi
You will need to write back the issue key of the created issue
and define more IFTTTs to create sub-tasks
Sub-tasks mappings could then use the value of a created key you got in step #1 and put back to the form's record in step #2
Alex
@Alex Medved _ConfiForms_ I currently have two ifttt macros, first is to create the jira issue and the second is to create/update confiforms entry.
I created a form field definition in the confiform 'jid' for the jira id to be written to and I've set the parameters in the second ifttt macro to:
entryId=[entry.id]&jid=${iftttResult_createJiraIssue}
But I'm getting an error of 'unknown macro: iftttResult_createJiraIssue'
if I update the parameters to entryId=[entry.id]&jid=iftttResult_createJiraIssue
The error goes away but it doesn't write to the confiform...
Also the video on the page you linked doesn't seem to load.
Appreciate any advice..
UPDATE: Even though there is the 'unknown error' it still writes the Jira Issue Key to the Confiform.
@Alex Medved _ConfiForms_ Would you be able to post an example of a sub-task mapping in a subsequent IFTTT to show how it should be done?
When you put {} in a macro parameters in Confluence the editor fails to render the macro's placeholder and says it's an "unknown macro".
Luckily it does not affect the functionality
Also, instead of ${iftttResult_createJiraIssue} you can have [iftttResult_createJiraIssue]
Alex
As for the sub-tasks - add more IFTTT rules (just after the IFTTT that updates your record with a Jira key) and set the "parent" in their JSON mappings to take the value from [entry.jid] field
Good and simple example of such mapping
Alex
Hi @Alex Medved _ConfiForms_ ,
Hoping you can help me out again, I've been able to use confiforms to create a jira issue and sub-tasks and link them together.
However, I'm now having trouble with attachments. How would you go about adding a file as an attachment to the jira issue that the confiform creates?
I need to take the attachment added to the confiform field (field type: file) and add it to an issue in jira.
I've tried using an IFTTT Integration rule to update Jira issue in the confiform, but have been unsuccessful so far.
The initial IFTTT writes the Jira Key back to the field JIRAKey and the Jira issue key is entered into the macro as [entry.JIRAKey]
The JSON in the No format macro within the IFTTT may be wrong? I currently have it as
"Update": {
"attachment": [
{"filename": "[entry.filefield]"}
Appreciate your help, if you know how this can be achieved.
Drew
Hi Drew
Attachments are not mapped via the JSON mapping, you just need to drop a ConfiForms Field macro, with field name set to you "file/attachment" field into the IFTTT macro body
Alex
Thanks @Alex Medved _ConfiForms_! Works perfectly and is much simpler than what I was trying to do.
Really appreciate your help!
Drew
Yes, it is much simpler.
The thing is - uploading attachments to Jira is a separate step from creating a Jira issue. That is why it is not in the JSON
