Hello Everyone,
I have 2 Jira setup and details are below,
Instance #1
Instance #2
As you can see, there are no plugin apps are installed in Instance #2, so we can call it as empty instance...
The issue is when I try to upload plugins, it throws 'unexpected error, refer logs' but there are no entries in logs...Then I checked browser's 'Developer console', which shows that 'Request Body is too large' as it refers to the app size that I am uploading...
So, I concluded that there maybe some issues with memory configuration in the Instance #2...but unable to determine where to look...
So, I tried increasing with request quota cpu and memory in Kubernetes for Pod running this Jira application but no effect.
The only area I haven't touched is the Java environment heap size at the moment. This is because I don't know how to update default Java heap size in Jira app running in a container as the Jira app uses Java heap configuration defined in 'setenv.sh' file.
So, I posted my question here to get some suggestions or ideas on below,
Your suggestions/opinions are very much appreciated.
Thank you.
Request Body is too large suggests that you need to configure your ingress to allow larger uploads.
Thank you for the reply... I figured it out and configured ingress "proxy-body-size" then everything working fine now. Appreciate your response Yevhen.
