Configure Project Templates 'Made for you Templates for you based on how similar teams work.' screen
Phil
How do I change the project templates that show on the 'Made for you
Templates for you based on how similar teams work.' screen.
We exclusively use company-managed Scrum projects but now Jira pushes my team to create team-managed Kanban boards. I try to delegate project creation to my team but the UI changes nearly every time they try and something goes wrong.
Trudy Claspill
Hello @Phil
I suspect that the answer is "You can't do that", but I'm not finding a screen with quite the same text on it that you mentioned.
Exactly how are you getting to that screen?
Can you provide a screen image?
How did you "delegate" project creation?
Phil
Hi @Trudy Claspill
I've added a screenshot to my original post (good idea).
This is just the screen I get when I create a new project.
I "delegated" by "asking them to do it" 😉
Thanks for your help.
Trudy Claspill
That screen is not customizable.
I found it described in these weekly release notes from April 2023
https://confluence.atlassian.com/cloud/blog/2023/04/atlassian-cloud-changes-apr-17-to-apr-24-2023
It is based on the type of team a user says they belong to when they go through the initial "welcome" screens the first time they access the Jira instance.
