Configured Screens not displayed on the project
Michelle Genrich
I created a Screen Scheme called 'Kanban Issue Type Screen Scheme'. I have also created Screens for the issue types of User Stories, Bugs, and Sub-Taks. These screens are part of the Kanban Issue Type Screen Scheme. I have one sample project created called Template Software Project that is using the Kanban Issue Type Scheme. But when I create/edit/view issues in the Project, I don't see the right fields or configuration. What am I doing wrong?
Here are my screen schemes:
screen schemes.pngHere is an example of the Kanban Bug Screen that I configured:
bug screen 2.pngWhen I create a new bug in the project Template Software Project, I don't see the tabs I configured.
Thanks for your help!
2 accepted
Walter Buggenhout
Hi @Michelle Genrich,
If you click the Configure Fields button in the top right corner of the Create Issue dialog, see if you have a link to show All fields.
Your tabs might appear after clicking that link:
Michelle Genrich
Thanks Walter, I saw that but I was confused by the screen scheme outside the project settings. Thanks so much for the help. Do you know if in the future there are plans to be able to create sections or choose to display certain fields on create vs edit? Another question is, can you still create screens that will be used in workflows?
Alexey Matveev
November 19, 2018
You use the New Jira Issue View. You can find more info here:
https://confluence.atlassian.com/jiracorecloud/the-new-jira-issue-view-938040503.html
Here is the extract from this document:
To choose which custom fields appear in the new issue view, head to Project settings > Screens, expand the appropriate screen scheme, select the View issuescreen to configure it. Field order isn't configurable in the new issue view just yet, but we're working on it.
Also there is this one:
The new issue view has one just screen, where you view, edit, transition, and comment. Click any field you see to edit it inline.
Michelle Genrich
Thanks Alexey. That article was very helpful. It sounds like right now, the issue screens is just a list of the fields you want, you can't create sections or things like that. Is that correct?
Alexey Matveev
November 21, 2018
Yes, it is correct. You can not change the view of the screen.
Michelle Genrich
Thanks @Alexey Matveev
