Connecting with Jira with 3rd Party App Using a Token
Kevin Passey June 27, 2023
Hi
I'm trying to connect to Jira from a IBMi change control system using a generated token.
All I get is - gsk_secure_soc_init-Error Code:6000 - Certificate is not signed by a trusted certificate authority.
I am assuming this is a problem on the IBMi side.
Has anybody seen this before?
Kevin
Aron Gombas _Midori_
It is a bit unclear, but I assume you're trying to connect to the Jira Cloud REST API using an  API token.
Each API token belongs to a valid Atlassian user account. For a properly authenticated request, you need to encode both the email address and the token to an HTTP request header, following the Basic auth rules.
See: https://developer.atlassian.com/cloud/jira/platform/basic-auth-for-rest-apis/
Kevin Passey June 29, 2023
Thanks Aron,
I suspect it has something to do with my java client submitting the http request.
There seems to be some trust issue with the remote host - so I think my java client setup on the IBMi is the problem - I've raised a ticket with the software developer.
Thanks for your response anyway.
FREE
