Is it possible to create a field configuration that uses a different set of inward and outward links from the default?
We have several departments that use Jira and and link issues. Some use the traditional "FS Predecessor, FS Successor" style of dependency while others use a more simple "Relates To, Related To" dependency. To limit confusion between the teams I'd like to have two or more lists and use the field configuration and field configuration scheme to separate them between departments.
Hi Scott,
if you want to put links into a context and add logics you should try out the advanced links from the app STAGIL Assets - Advanced Links. The app even supports the creation of custom link and data models and allows you to manage links via fields and custom panels in the view screen. You can request a demo via support@stagil.com.
Best regards
Björn
Thanks @Björn Frauen [STAGIL]
I don't have the option to use add-on apps, so I'm hoping for an out of the box solution.
-Scott
