Converting JIRA sub-tasks to parent issues
Walt Harper
Another administrator is trying to convert a sub-task in a Story, to an actual Story (bigger than originally thought). But it does not show up in her Issue Menu, but it does show up for me? Why is that?
Nic Brough -Adaptavist-
July 16, 2018
Do you have create and edit issue permission in the project?  (Remember admin rights are not project rights)
Walt Harper
So I've figured out that it's missing on the New Jira Issue View. Discovered when she went to Personal Settings and toggled OFF the New Jira Issue View, Convert to Issue shows up with the same menu as mine.
July 16, 2018
Ahh, well spotted!
Another thing in the new view that's broken.  It's not even ready to beta I reckon!
Alexey Matveev
July 16, 2018
Do you mean that the user does not have the Convert to Issue menu option?
Walt Harper
Correct...this is a System Administrator and also (now that I've added her) a Project Administrator AND Project Developer Roles on the projects...still no "Convert to Issue" option under the edit menu.
Alexey Matveev
July 16, 2018
Then kindly check permission as @Nic Brough -Adaptavist- mentioned. Also make sure that you are trying convert a sub-task
