Copy a project
Pauline Hild
I am using Jira Work Management and would like to copy one of my projects to be able to test a new automation there without it affecting the running tasks in the project in case there are still issues with the automation. Unfortunately I can't find the option "Copy" anywhere, only "move to trash" and "project settings".
Can someone help me how to find the option to copy a project?
Pauline
John Funk
Hi Pauline,
You can't "copy" a project. You can create a project based on an existing project - which you should do. Then you can use an Automation Rule to clone the current issues in your production project to the test project.
Pauline Hild
Hi John, thanks for your answer!
Like John Funk likes this
John Funk
You are welcome!
David Drong-Reisch
Sorry for asking, but how??
Like Raphael Hirt likes this
Marsel Meeuwsen
March 29, 2023
Indeed, how? @John Funk ?
John Funk
Hi @Marsel Meeuwsen  - It's better to create a new question in Community so that more people will see it and can help respond. Answers can also be tailored to your individual need.
Thong Tran
February 15, 2024
You can Create new Project > Clone Task from Project what you want duplicate/copy > Move this Task to your new Project.
Marlene Kegel - codefortynine
Hello @Pauline Hild,
I am Marlene from codefortynine.
If you you are not able to clone all needed issue data with automation, you can check out Deep Clone for Jira to clone your project.
It is possible to clone team-managed and company-managed projects. You can read more about the Deep Clone Project Clone in our documentation.
Please that you have to enable the Advanced Project Clone if you want to clone team-managed projects or project boards of company-managed projects.
