×I added an automation rule, and it works. However when issues link relations have several steps, it doesn't work.
Issue A comment
ㄴ Issue B copied comment --> success
ㄴ Issue C not copied comment --> failed
When copied comment to Issue B by an automation rule, it can't be a trigger. Audit log displays "No related issues could be found".
How can I fix it?
Hi @jun lee
You have to enable the automation to be triggered if triggered by automation, it's a checkbox to check in the automation detail where you set the owner and actor.
Be careful to make sure it will not loop.
Regards
