Create Issue with Insight customfield filled
Christof Hurst
Hi community,
I want to create issues via groovy and want to set an Insight customfield. But I didn't get the correct syntax. Neither with object, objectId or objectKey I'm able to fill the field.
Did anybody have tips?
import com.atlassian.jira.issue.IssueInputParameters
import com.atlassian.jira.bc.issue.IssueService.IssueResult
import com.atlassian.jira.bc.issue.IssueService.CreateValidationResult
String[] putObject = [objectBean]
//String[] putObject = [objectBean.id]
//String[] putObject = [objectBean.objectKey]
Long cfId = 12345L
Long projectId = 11111L
String issueTypeId = "22222"
String summary = "TestSummary"
def reporter = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def issueService = ComponentAccessor.issueService
IssueInputParameters issueInputParameters = issueService.newIssueInputParameters()
.setProjectId(projectId)
.setIssueTypeId(issueTypeId)
.setSummary(summary)
.setReporterId(reporter.name)
issueInputParameters.addCustomFieldValue(cfId, putObject)
CreateValidationResult createValidationResult = issueService.validateCreate(reporter, issueInputParameters)
if (createValidationResult?.isValid()) {
IssueResult createResult = issueService.create(reporter, createValidationResult)
if (!createResult.isValid()) {
return null
} else {
return createResult.issue
return null
Christof Hurst
I think it is the field dependencies to other insight fields. If they are not filled in the correct order, then the value (or id) is discarded.
Hana Kučerová
Hi @Christof Hurst ,
welcome to the Atlassian Community!
It seems to me the problem could be in the variable putObject.
When you want to store insight objects, the variable needs to be
List<ObjectBean>
i.e list of objects.
Where do you have this script? How do you obtain "objectBean"?
Thank you.
Christof Hurst
the objectBean is fetched from various places. It's a general problem. But it's always the same class. In most cases it works with [objectBean.objectKey]. Maybe sometimes it fails because the customfield configuration depends on former fields to be set.
Nevertheless it works when setting the fields after creation via
createdIssue.setCustomFieldValue(cf,[objectBean])
In that case the objectBean was retrieved by
def objectBean = issue.getCustomFieldValue(cf)[0]
