We use the function frequently to create a new project in Jira. Basing it off of an existing project makes sure it the setup is correct.
Now it seems there have been several updates around projects and this option just dissapeared?
Are there anywhere settings to bring this essential functionality back?
Hello Dominic.
This functionality still exists, it's just a little harder to find. When you go to create a project, you need to change the template that is used. Scroll all the way to the bottom and there is "Create with shared configuration".
Hello Kian,
Thanks for your reply.
Looks like there was some update in progress yesterday since I knew it was all the way on the bottom before, but yesterday it was just not around.
But great to see its back :)
