Hey,
I had a Certification these days and I remember one question that confused me. It was about:
You create a project with shared configuration. Which Schemes are unique for the new project?
- Permission Scheme
- Issue Type Scheme
- Field Configuration Scheme
- Issue Security Scheme
- Workflow Scheme
Two answers are correct. But in my opinion all of them are shared with the original project. I had a look for this and only the Issue Type Scheme is not mentioned as shared in the Project Settings (but I'd say it was at least copied, so it's not 'unique').
Does anybody have an idea about this? Or maybe I don't see the forest for the trees..
Hm. Before I did a test, I'd even say it's the security scheme. But look at this screenshot @Pete Singleton @Fernando Bordallo ....
Isn't that shared ...???
I also had a Certification and I have the same puzzle as you.
Actually, all scheme can be shard.
I think the question has no right answer.
But when I am having the certification, I am confused too.
I think Issue Security Scheme is the other one
Indeed. There are interesting views into a future where project configurations and templates are handled in a modernized (ecosystem-style) way with next-gen. :)
