Create Scripted Field using Adaptavist ScriptRunner for Jira
Will Fry September 28, 2018
In the documentation for ScriptRunner, there seems to be an option to create a Custom Field, however, no such option is available in the add-on page in JIRA.
Have there been changes to ScriptRunner?
Docs Screenshot
Add-ons Screenshot
Sid
September 28, 2018
Screen Shot 2018-09-28 at 10.15.21 AM.pngHi Will,
You can add a scripted filed in here
Under Addons; you can find the scripted fields
thanks
Hi @Sid - As per my screenshot, it does not appear. After emailing Adaptavist, it seems like Scripted Fields are not supported in JIRA Cloud only JIRA Server.
Has anyone found a work-around for achieving similar functionality?
Sid
September 28, 2018
Hi Will,
If cloud version does not support the scripted fields, the workaround would be using the workflow post functions based on your use cases there might be multiple workflow plugins that might solve your problem :)
