Create a issue using different fields
saikrishna2200
January 9, 2019
I am trying to create a JIRA issue using rest api. I wonder how the fields are provided. I see that there are different ways. For example:
1. For summary field, it is just key an value.
2.  For description, it is json object with key "set".
Is there any generic way to find how the fields needs the value to be set?
Steven F Behnke
January 9, 2019
Covered on the documentation: https://developer.atlassian.com/server/jira/platform/jira-rest-api-examples/
Editing an issue by using the SET, ADD, and REMOVE operations. Not all fields support all operations, but as a general rule, single value fields support SET, whereas multi-value fields support SET, ADD, and REMOVE, where SET replaces the field contents while ADD and REMOVE add or remove one or more values from the the current list of values.
saikrishna2200
January 9, 2019
The above link you have provided is for the custom fields. How about the Jira Core std. Fields?
Steven F Behnke
January 10, 2019
There are NUMEROUS examples of standard fields being updated on that page.
Gonchik Tsymzhitov
