Is it possible to create a rule where I cannot move an isso from an epic if another issue of the same epic is not on the same column (Status)
Example: Task 1 and Task 2 are both from Epic Test.
I would like to set a rule where Task 2 cannot progress from the column QA to Waiting PO Approval without Task 1 being on QA too
@Filipe Dziedicz is the requirement that a single issue must be in the status, or that all of them must be? I am not sure of what you are trying to do is possible or not, but I want to make sure I understand the requirements!
thanks,
Kian
I would like to divide the board in some way, I tried using configurations of workflow so that Not issue of the same epic should go to Waiting PO Approval without all issues of the same Epic be on QA (The last column before Waiting PO Approval)
@Filipe Dziedicz,
I don't think there is any way to do this easily. You could look at the JSU Plugin. This has a "linked status" validator which could potentially be used, but I think you would need to link all of the tickets in the Epic together, which might be kind of a pain to do.
Kian
