Hi there
I use business projects in Jira.
I want to work with sprints, but don't see a way to create sprints for business projects.
What can I do ?
Hi @Tal Stanek
It is not applicable for business projects. You should convert a project to software if you have Jira Software subscription.
Best
That's not an applicable answer.
I use business projects for a reason, so why converting ?
Anyway, I wasn't expecting a different answer.
Thanks!
Do you have Jira Software subscription in cloud?
Alternatively, you can create a board and include the project in a board filter to return issues. It will allow you associate the board to your profile but not the project itself.
I have Jira Software, but won't convert as I'm using the Jira Work.
I just created a custom field and it's a fairly good solution.
Tal
