Create an Issue with third party field through rest api
G Ramachandra August 29, 2017
Hi Team,
while creating the issue through REST API, 'Team' field of JIRA Portfolio is not populating.
I am trying to update Team with Custom ID: customfield_10300.
your immediate help is highly appreciated
Thanks and Regards
Ramachandra Reddy
Steven F Behnke
September 1, 2017
@G Ramachandra, can you show us the code you're using and the response from the server?
G Ramachandra September 1, 2017
Hi @Steven F Behnke,
please find my code as below.
RestClient client = new RestClient("https://myproject.atlassian.net/rest/api/2");
RestRequest request = new RestRequest("issue/", Method.POST);
client.Authenticator = new HttpBasicAuthenticator(txtJIRAUN.Text, txtJIRAUP.Text);
createIssue(request, client);
private void createIssue(RestRequest request, RestClient client)
try
var issue = new Issue
fields =
new Fields
description = JiraDesc,
summary = _tfsTitle,
project = new Project { key = "ProjectName" },
issuetype = new IssueType { name = "IssueType" },
priority = new Priority { name = _priority },
customfield_10400 = _tfsID,
customfield_11201 = _custName,
customfield_11500 = _supportid,
customfield_11100 = new Customfield_11100 { value = _itemType },
customfield_10300 = "TestTeam",
request.RequestFormat = DataFormat.Json;
request.AddJsonBody(issue);
var res = client.Execute<Issue>(request);
if (res.StatusDescription == "Created")
_jiraKey = res.Data.key;
bg.ReportProgress(0, "Issue Created, Id: " + _jiraKey);
else
bg.ReportProgress(0, "Issue Not Created.");
catch (Exception ex)
throw new Exception(ex.Message);
public class Issue
public string id { get; set; }
public string key { get; set; }
public Fields fields { get; set; }
public class Fields
public Project project { get; set; }
public IssueType issuetype { get; set; }
public Priority priority { get; set; }
public string summary { get; set; }
public string description { get; set; }
public string customfield_10400 { get; set; }
public string customfield_11500 { get; set; }
public string customfield_11201 { get; set; }
public Customfield_11100 customfield_11100 { get; set; }
public string customfield_10300 { get; set; }
public class Project
public class IssueType
public string name { get; set; }
public class Priority
public class Customfield_11100
public string value { get; set; }
And Response from JIRA server as below
Steven F Behnke
September 1, 2017
Okay, the error clearly states the problem.
Team with ID 'TestTeam' could not be found
Can you create an issue in JIRA with the Team field set to TestTeam and perform an HTTP GET on /rest/api/2/issue/issueKey so you know what you need to send to JIRA?
TestTeam is available in Team field in JIRA. I can select Team field as TestTeam in JIRA, It's working fine.
Steven F Behnke
September 1, 2017
You're not passing the right value.
I am passing TestTeam as below. (as mention in my code)
anything wrong here..
Steven F Behnke
September 1, 2017
Can you perform an HTTP GET on an issue with it so you can see what value is stored? If the API isn't documented you should at least take a look at the GET shape and we can hope it's the same shape to POST/PUT.
Andy Heinzer
August 30, 2017
JIRA won't let you create a new field during an issue creation/update.  Those fields have to exist in JIRA already before you can update a value for that field on that issue.
There is a way to create new custom fields via REST as per https://docs.atlassian.com/jira/REST/server/#api/2/field
Alternatively you can also create the custom field with that name in the JIRA GUI as explained in Adding a Custom Field.   Please note that when you first create a custom field in JIRA, you will probably have to reindex JIRA in order to then be able to use that new custom field.
