Create an automation rule for due date and start date
Silvia Fattori
October 29, 2020
Is it possible to create an automation rule that assigns to the due date of a story the due date valor most future present among all the present issues of that project?
Then I would like to do the same thing with the start date, taking the most recent date present.
For example
Thank you
Bill Sheboy
October 29, 2020
Hi @Silvia Fattori  -- Welcome to the Atlassian Community!
You probably can do that using the list and math functions.  It may require the use of a temp variable (create variable or custom field) to retain the value.
And, the techniques would be different if you are using sub-tasks versus the other issue types, as sub-tasks are already a list and you could find the maximum date immediately: {{issue.subtasks.Due date.max}}
What have you tried thus far to do this?
Best regards,
Silvia Fattori
October 30, 2020
Thank you for your quick response.
My search for two max dates should be done on all types of issues in the project (so not only subtask). I would need to know how to put it in the automations.
Bill Sheboy
October 30, 2020
Hi @Silvia Fattori
For more details, here is an example to set the Due Date for a specific Epic...
  • Trigger: Due Date is changed
  • Condition: related issue, check this issue has an Epic
  • Branch: on the Epic (Parent) of this issue
    • Condition: if the story Due Date {{triggerIssue.dueDate}} is greater than the parent Epic Due Date {{issue.dueDate}}
      • Action: set the epic's Due Date to the value from the triggerIssue Due Date
If you wanted to check a Due Date spanning all issues in a project you could use a created variable and iterate using a different branch JQL filter...but, you will need to pick an issue to store the maximum value into, such as a specific Epic.
__Bill
Like # people like this
David Ashlock
Hi @Silvia Fattori , this can be done with the {{lookupissues.Due date.max}} and {{lookupissues.Start date.min}} smart value functions.  See attached.
Bill Sheboy
March 2, 2022
Yes, indeed.  Those fields did not exist in Lookup Issues when this question was first posted, so the solution is now easier to implement.
David Ashlock
Haha!  I figured so or you would have suggested it.
@Bill Sheboy i was actually looking for a way to specifically ask you if you can do the following:
{{lookupissues.Due date.max.diff(issue.Start date).businessDays}}
I believe you can, but I'm having an issue getting the max due date to come through (separate issue).
Bill Sheboy
March 2, 2022
Hi @David Ashlock
Yup, and I believe you just have a couple of smart value capitalization and spacing issues...this worked for me:
{{lookupIssues.duedate.max.diff(issue.Start date).businessDays}}
Like David Ashlock likes this
David Ashlock
@Bill Sheboy
Thank you!
One follow-up question -- if your lookupIssues only has a single value, does the .max function still work?  When I removed that, everything worked -- note that there is only one issue blocking my test issue, but there could be more in the future.
David Ashlock
@Bill Sheboy
I think you can ignore this question -- the capitalization and space issues seem to have fixed that problem as well -- never realized it was going to be that picky!
Thanks again!
Like Bill Sheboy likes this
