Create an issue from a Scriptrunner Job with customfields
Joseph Fowler October 6, 2021
I have a scriptrunner job that  creates an issue based off of a JQL query result. All of that works  fine and the issue gets created. However, I want to be able to add a value to a custom field that is a radio button. I have use options manager and found the option and then use  setCustomFieldValue(cf, value) and it still is not liking it. I work in an environment where i can not share my code, if anyone has any tips that would greatly be appreciated. Also, I got around it by letting the job create the issue without the custom field and then have a listener wait for the creation of the issue and then i can update the value of the custom field. This is a workaround i want to get rid of because I need to make the custom field  required.
EDIT: Added code block below.
import com.atlassian.jira.bc.search.SearchService
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.web.bean.PagerFilter
import com.atlassian.jira.issue.search.SearchQuery
import com.atlassian.jira.issue.context.IssueContext
import com.atlassian.jira.issue.context.IssueContextImpl
import com.atlassian.jira.issue.fields.config.manager.PrioritySchemeManager
import com.atlassian.jira.issue.customfields.manager.OptionsManager
def user = ComponentsAccessor.jiraAuthentiationContext.loggedInUser
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
def searchService = ComponentAccessor.getComponent(SearchService)
def issueService = CompnentAccessor.issueService
def constantsManager = ComponentAccessor.contanstsManager
def optionsManager = ComponentAccessor.getComponent(OptionsManager)
def jqlSearch = "project = TEST AND created >= startOfDay(-4h)
def query = jqlQueryParser.parseQuery(jqlSearch)
def results = searchService.search(user,query,PagerFilter.getUnlimitedFilter())
if (results == null) return
final projectKey = 'TEST'
final issueTypeName = 'Test Issue'
final reporterKey = 'admin'
final summary = 'Test Entry'
final description = 'Test Description'
def project = ComponentAccessor.projectManager.getProjectObjByKey(projectKey)
def issueType = constantsManager.allIssueTypeObjects.findByName(issueTypeName)
def issueContext = new IssueContextImpl(project, issueType) as IssueContext
def reporter = ComponentAccessor.userManager.getUSerByKey(reporterKey) ?: user
def cf = customFieldManager.getCustomFieldObject("customfield_10902")
def fieldConfig = cf.getRelevantConfig(issueContext)
def option = optionsManager.getOptions(fieldConfig).getOptionForValue("Yes", null)
def issueInputParameters = issueService.newIssueInputParameters();
issueInputParameters.setProjectId(project.id)
issueInputParameters.setIssueTypeId(issueType.id)
issueInputParameters.setReporterId(reporter.name)
issueInputParameters.setSummary(summary)
issueInputParameters.setDescription(description)
issueInputParameters.setCustomFieldValue("customfield_10902", option)
//issueInputParameters.addCustomFieldValue("customfield_10902", option)
//issueInputParameters.setCustomFieldValue("customfield_10902", "Yes")
def validationResult = issueService.validateCreate(user, issueInputParameters)
def result = issueService.create(user, validationResult)
return
Matti Dennstaedt May 5, 2022
Hi Joseph,
it needs the ID of the option. I just had the same problem. If you change your line as follows, it should work:
def option = optionsManager.getOptions(fieldConfig).getOptionForValue("Vorinstallation (Initial)", null).getOptionId()
issueInputParameters.setCustomFieldValue("customfield_10902", option.toString())
 It is returned type long and must be converted to string.
Will C
October 7, 2021
it sounds like you are doing the right thing by updating this custom field using options manager, and if that works in a listener for this field it should work in a job, we would need to see your code to comment on where it is going wrong.
Make sure you are saving the value after you are setting it, but if you are doing that in a listener its the same in a job.
Joseph Fowler October 7, 2021
Im doing this in a job that runs once every night. I added the code block above of what I am doing. There may be some stuff in there thats not used anymore, but left in there from me trying all sorts of things to get custom field values in there.
Will C
October 14, 2021
I'm not sure what the JQL search has to do with creating the task? Do you create a new task for every result the JQL returns?
I've tried to look at your script but there are a lot of errors in there when trying to run on the console, is this exactly what you are running?
Joseph Fowler October 21, 2021
Sorry i typed this up, I can't get the full code block. I work in a sensitive environment. This is just a gist of it from memory here. I create an issue if the search results returns no entries. Literally just want to create an issue in a job with custom fields that are select lists and radio buttons. Thats all i want to do
