Create another Jira Project
Cristina - Elena Andrei
It is possible to have 2 Jira Projects with the same name even one if of those is archived?
Mikael Sandberg
You will get a warning if you are trying to create a second project with the same name as an existing one. And if you are trying to reuse the project key you would have to move the existing project to the trash and then permanently delete it before reusing it.
Thank you, I was thinking that is possible to have 2 projects with the same name but with different project key.
Trudy Claspill
Actually you can have projects with the same name, as long as they have different keys.
thank you
Mikael Sandberg
My bad, you will get a warning if you reuse the same name
FREE
