We would like create following scheme for JIRA Schema for C1 Roadmap.
We are not able to create Child relationship in the project.
Example
Hello @Maktumhusain Taseeladar
Are you using a Standard or Premium subscription of Jira Cloud?
Be advised that only the Premium subscription includes Advanced Roadmaps which enables you to extend the issue hierarchy upwards only above the Epic level. The functionality does not support adding hierarchy levels below Epic.
The default hierarchy is
Epic > general issue types (Story, Task, Bug, etc.) > Sub-task
Also, where you are showing "Task" you would have to use a Sub-task type of issue
We are using Premium subscription of Jira Cloud. Thanks,
Here is a link to the documentation about creating custom issue hierarchies in the Jira Software Premium subscription.
