Create issue post function HELP PLEASE!!!!
Bruno Farace February 5, 2021
Hi everyone!
!!!!Calling all Jira enthusiasts!!!!
I really need help with a topic I have been stuck on for WEEEEKS!
Context
I have a request to set up an email to ticket function on Jira which I have completed.
(The email is sent from a company email address: Billing-finance@XXXX.XXX)
This has been set up so that the reporter of the ticket is the requester who sent the email to above address.
So now my problem:
How can I configure the post function of CREATE ISSUE to update the following fields with specific values:
  • Labels
  • Components
This needs to be done ONLY when the ticket is created via the email automation
What have i tried?
Creating a post function with following criteria:
  • Update Any Issue Field (JSU) Function for this transition
    • Precondition True
    • Update field: within same issue
    • Perform as user: Billing-finance@XXXX.XXX
    • Issue field: Labels & Components
    • Field value: [as requested]
Outcome
After configuring this the desired fields are indeed updated BUT this happens when ANY user creates an issue.
This topic is starting to make me go a bit crazy and I would be so grateful if anyone out there could put me out of my misery.
Many thanks in advance!!!
Jack Brickey
You can’t do this with a PF. You would need some from of automation addon or scripting addon. Unless server has some new means I’m unaware of.
Manuel Galván
You can use scriptrunner email handler to inform a customfield (for example origin = mail) and use this field in post function conditions
Jennifer Flinn
You can also use the ScriptRunner email handler to set the component and label on issue creation (without having to add anything to the workflow post-functions).
Daniel Ebers
February 7, 2021
Do I get it correctly that
is the mailbox on your customers/partner side which is mapped to the same named reporter in your instance?
Assuming this I am just wondering if it would not work out if you replace
Perform as user: Billing-finance@XXXX.XXX with the reporter set to Billing-finance@XXXX.XXX
My assumption is that the logic with your settings is executed with the user you mention but _applies_ to all issues.
With the reporter as the criteria it would have more logic for me but it could be wrong.
Matt Tsugawa
February 5, 2021
The behavior you described is what I'd expect to happen. As Jack stated, you need an addon app for that. I have used this one and it will do what you want by installing the features you were looking for in the places you expected. Note that I am not affiliated with this addon company in any way.
https://marketplace.atlassian.com/apps/292/jira-misc-workflow-extensions-jmwe?hosting=cloud&tab=overview
