Create multiple level subtasks for Work Breakdown Structure (WBS) in Jira
Zhuo Wang September 16, 2021
I am currently trying to create multiple-level subtasks for WBS on Jira Business Project. However, the current Jira Business Project can only generate Task & one-level Subtask. Does anybody have experience in generating subtasks for each subtask?
Thank you
Robert Wen_Cprime_
Out-of-the-box Jira projects have at most a 3-level hierarchy on issue types.  If you need to extend that hierarchy, you need to look at a Marketplace app like Structure.
Hi Robert,
Thanks for your recommendation. I will take a look at Structure app in Marketplace.
Zhuo
Like Dave Rosenlund _Trundl_ likes this
Zhuo Wang September 20, 2021
Hello Robert,
I installed the Structure plugin in our cloud JIRA environment. We are currently in the plugin's trial period. Using the Cloud version Structure, we still cannot move subtasks left and right, because "Manual Adjustment" cannot be set up even though I have admin privileges.
Some people mentioned that Server version can solve this problem? Since there are several options for Structure, Do you know which one is the right version to use for this problem?
Thank you very much for your help!
Zhuo
Stepan Kholodov _ALM Works_
Hello Zhuo,
We'll be glad to provide more information about Structure and help you to achieve what want with it, if possible. Please contact us directly at support.almworks.com for proper support and we'll get back to you shortly.
Best regards,
Stepan Kholodov
ALM Works
Zhuo Wang September 22, 2021
Hello Stepan,
I just sent an email to support@almworks.com. Hopefully could get the proper support from them.
Best regards,
Zhuo
Anna-BigPicture
Hi @Zhuo Wang
If you consider using an additional application, BigPicture/BigGantt seems to be a good match!
With this plugin, you can create an automatic,  no-limited number of WBS levels. Task Structure can be created based on both build-in task attributes (e.g., Epic link, Component, Version, Sprint) as well as Jira links (e.g., Parent-Child relation).
Here, you will find a short video presenting how to create desired task structure (WBS) in BigPicture/BigGantt. I hope you will find it helpful.
Anna
Hi Anna,
I did some research on BigPictures/BigGantt and watched the short video, and found it is an option to create WBS task structure.
Thank you very much for your information,
Zhuo
Like Anna-BigPicture likes this
Anna-BigPicture
Hi @Zhuo Wang
You are welcome! Please remember to tag me in case of further questions. I will gladly answer.
Have a good day!
Jacob Vu
September 16, 2021
Hi @Zhuo Wang
You're able to use Epics -> Stories/Tasks -> sub-tasks in terms of hierarchy, which gives you three levels of hierarchy.
If you're looking to break down work even further in a WBS, the easiest way to do so is via Advanced Roadmaps but it is offered as a Jira Software Premium service only. When you enable Advanced Roadmaps, it allows you to create multiple levels of hierarchies and comes out of the box as a feature with Jira Software Premium.
As Robert mentioned above, you could do this via a third-party app too if you don't have Jira Software Premium or don't want to upgrade due to costs.
Finally, you can check out our blog on this as well.
Jacob
Hi Jacob,
I can find Epics from Jira Software, but now I use different project (Jira Business Project) to manage tasks. I will check out your blog and the third-party app.
Thank you,
Zhuo
Jacob Vu
September 16, 2021
Hi @Zhuo Wang
You can add Epics and Stories as issue types to your Jira Business project. Similar in hierarchy but you wouldn't have the ability to create custom hierarchies. Apologies for missing that you're using Jira Business project instead of Jira Software.
If you are using Jira for project management though, I'd suggest looking into using Jira Software as combined with Advanced Roadmaps or even Roadmaps. Allows you to create Plans, Programs and the ability to create Roadmaps.
Jacob
