I created an Epic and link some user stories to it using advanced roadmap in jira, when I saved the changes all of them (Epic and user stories) disappeared from plan and I don't know what can I do to include them again
Hi @AgileHappyLearner ~ check your Plan's Issue Sources. It probably isn't included and you'd just need to tweak either your issue sources or the Epic details.
Thanks for your answer, I found the problem and it was that Epics and User Stories weren't included in the filter used for backlog
